75 100ls
Old Dec 1, 1999 | 01:52 PM
WarrenY
Guest
Posts: n/a
Default 75 100ls
Anyone know where I can find some info on this car? My aunt gave me one with the shop manual for a 73 and earlier...thus, no info on the fuel injection stuff (Well...I'm no mechanic...I could be looking in the wrong place, but I've gone thru the fuel system section a couple times now). Thanks for any info...
W
Old Dec 2, 1999 | 09:07 AM
Tony
Guest
Posts: n/a
Default Used to have a 74 100LS, no manual anymore, but ask a question.
nt
Old Dec 3, 1999 | 12:05 PM
Hans
Guest
Posts: n/a
I could never keep the car tuned. Great car when running. Good luck.
Old Dec 6, 1999 | 02:50 PM
WarrenY
Guest
Posts: n/a
Default Re: Used to have a 74 100LS, no manual anymore, but ask a question.
Hi Tony,
Ok, two hopefully stupid questions.
1) I need to replace the fuel filter. My manual is a 73 and the 73 was carburated. The 75 was the first year for fuel injection and I don't know where the fuel filter is located, nor do I know where to look.
2) The brake lights don't work (though the tail lights do light up on turning headlights on). I can't locate the switch for the brake lights...The fuses look good as do the bulbs.
Thanks!
W
Old Dec 7, 1999 | 08:52 AM
Tony
Guest
Posts: n/a
Default Some answers : more
These are just educated guesses, based on lots of VW / Audi experience.
Fuel filter is either in the engine compartment, by the strut tower, or underneath the rear, near the fuel tank. Filter looks like a 6"diameter by 6" long can, with a fuel line on each end. Dont confuse it with the fuel damper, which may be near the filter and pump, but has 2 fuel lines, both on one end. The fuel pump has some wires to it.
The brake lights are typically activated by either a switch located under the dash, on the brake pedal, or a one or two wire hydraulic switch, typically screwed into the body of the master cylinder, in the engine compartment, about the sixe of a half-dollar.
Old Dec 7, 1999 | 12:51 PM
WarrenY
Guest
Posts: n/a
Default Re: Some answers : more
Cool...I think the fuel filter is in the engine compartment as the mechanic pointed in that general direction and said I could swap it on my own.
As for the brake switch, I've taken apart the underside of the dash and have found nothing resembling a switch so I thought it might be attached to the master cylinder. However, I wasn't really sure what to be looking for...I'll go look again.
Thanks for the help!
W<ul><li><a href="http://www.kuci.org/~wyang/pics/audi/100">Pics of the 100...mostly all original </a></li></ul>
Old Dec 7, 1999 | 02:34 PM
Tony
Guest
Posts: n/a
Default MUST depressurize fuel system before loosening the fuel lines @ filter ! more
Pull the fuel pump fuse, or relay out, then crank starter for 15 to 20 seconds.
kmongru
Q5/SQ5 MKI (8R) Discussion
Mar 24, 2018 05:57 PM
rn4thbrdr14
Apr 10, 2012 07:43 PM
NiceS4
10
Mar 28, 2006 08:07 AM
AlLueb
Audi 100 / A6 (C4 Platform)
Aug 21, 2004 07:38 AM
?lueshirt
Aug 4, 2002 05:23 PM
