'93 90s auto trans. electrical problem
Old May 31, 2000 | 03:02 PM
stephanie2's Avatar
New Member
Default '93 90s auto trans. electrical problem
I'm having an intermittant problem with the automatic transmission on my
1993 Audi 90s. I've spent lots of cash but nobody can seem to fix my car.
I believe it is an electical problem:
When driving the tach. needle will swing wildly or
drop to zero RPMs. This is occaisionally followed by the transmission
down-shifting suddenly and searching for the right gear (very unnerving at
65 mph).
The transmission hasn't flipped out while in the manual range, gears 1-3 (of course I can't drive faster than about 50 mph in third).
Sometimes when I start the car the tach. needle stays at zero.
An independant mechanic replaced the RPM sensor but it didn't fix the
problem. The Audi dealers tell me there's nothing wrong with my car.
Does anybody know what the problem might be?
Old Jun 6, 2000 | 06:23 AM
ARK's Avatar
ARK
Did Audi dealer read the DTCs (Diagnostic Trouble Codes) from the transmission control module??
Old Jun 6, 2000 | 06:27 AM
ARK's Avatar
ARK
Default more...
The RPM sensor on the engine sends a signal to the Fuel Injection ECM, which then sends the RPM signal to the Tach, cruise control, and Transmission Control Module (TCM). It sounds like an intermittant connection between the ECM RPM output signal, to the TCM. The TCM would probably store a DTC if the RPM signal is absent. Ask dealer to hook up the VAG scan computer, and see if any DTCs are stored in the TCM. Its pobably a loose wire / connector.
Old Jun 19, 2000 | 11:59 AM
stephanie2's Avatar
New Member
Default Re: Did Audi dealer read the DTCs (Diagnostic Trouble Codes) from the transmission control module??
Thanks for your response, Tony. The Audi dealer told me that he didn't get any trouble codes from the engine. . . I don't know if that means he checked the transmission for codes too?
The independent mechanic replaced both the TPS and RPM sensors with no results. He wants to "tear it apart" to find the problem. Do you think this is a good idea?
Thanks,
Stephanie
mik61
Mar 6, 2012 03:59 PM
Frank_Oj
A4 (B7 Platform) Discussion
Feb 18, 2011 04:54 PM
jori
Jun 20, 2010 06:53 PM
davepp
Audi 100 / A6 (C4 Platform)
Sep 7, 2006 12:44 PM
Goatboy2k
Jul 23, 2001 02:39 AM
