another malfunction indicator light question...
Old Feb 20, 1999 | 05:13 AM
Dennis DiMatteo
Guest
Posts: n/a
Default another malfunction indicator light question...
I added a Wett chip and Ramair filter to my '99 A6Quattro last wk, noticed some hesitation, poor response and I think I found the problem. Suddenly , the MIL light went on, I opened the hood and saw that I must have failed to tighten one of the hoses on the air filter system. After reconnecting , the car was great! However, the light is still on. I've read the threads on the malfunction indicator light and I have a few questions that weren't answered;<br>1. Can I turn it off , myself?<br>2. If I bring the car in, can I tell the dealer I changed the filter (not the chip) will he detect it when he re-calibrates the ECM?<br>Thanks , Dennis<br>
Old Feb 20, 1999 | 07:45 AM
Insider
Guest
Posts: n/a
Default Re: another malfunction indicator light question...
The only way to turn the light off w/o a 1551/52 is to remove the ecu for appox 20 min. It will forget after the capisitors run down. The dealer will just pick up a excessive lean condition from the DTC.
Old Feb 20, 1999 | 08:13 PM
Ray Calvo
Guest
Posts: n/a
Default Just a thought - can the battery be disconnected for an hour or so, then reconnected?
I thought that's what my service manual for my Coupe Quattro said to do.
Old Feb 21, 1999 | 04:36 AM
Insider
Guest
Posts: n/a
Default Re: Just a thought - can the battery be disconnected for an hour or so, then reconnected?
Not always effective, there is a lot of residule voltage floating around the various control units in these cars.It may or may not forget. Plus then you pick up a lot of low voltage faults in other systems.particularly air bag control. Then there is always the radio code thing.
Ming02
Jan 17, 2006 11:45 AM
Timbo717200
May 7, 2005 06:22 AM
Solarant
Audi 100 / A6 (C4 Platform)
Dec 21, 2002 01:31 PM
98.5_2.8
Sep 20, 2001 10:31 AM
joe
Jan 5, 2000 05:19 AM
