Changing the ATF in an Audi80
Old May 4, 2001 | 01:46 PM
KidoSenkan's Avatar
New Member
Default Changing the ATF in an Audi80
Is it possible to change the ATF on my own? What do I need to keep in mind? also, what grade ATF should i be using? the manual simply says Dexron, but the only Dexrons i can find are the DexronII and DexronIII.
It would be great to be able to get a step by step process. the toughest maintenance i've done myself on the car was replacing the radiator fan belt
Thanks a bunch!
Old May 4, 2001 | 02:41 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Re: What year 80?
Old May 4, 2001 | 04:07 PM
DJ Springer's Avatar
25 Year Member
1990 fwd
Old May 5, 2001 | 07:15 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Drop trans pan and change filter too!
Then you'll need to change the fluid in the torque converter. This can be accomplished by
adding quarts, driving, and siphoning out through the dip stick tube. Do so untill fluid removed looks and smells just like the new stuff your putting in.
Recommend a synthetic oil!
I run Mobil 1 synthetic trans oil.
Also ya might want to check/change your differential oil.
nahid991
Dec 5, 2017 05:39 PM
KraTToR
Q5/SQ5 MKI (8R) Discussion
9
Aug 29, 2014 08:39 PM
WENR
26
Oct 30, 2003 10:43 AM
quattrofrog
Apr 14, 2003 07:09 AM
Eduardo Velázquez
Jan 5, 2000 12:54 AM
