Chirping from right front wheel
Old Aug 2, 2000 | 10:50 AM
srg3037's Avatar
Default Chirping from right front wheel
Car: 1989 200 TQ
When I drive I notice a chirping noise that is coming from my right front wheel, the faster I go the more faster it chirps. It is fairly loud and goes away when I apply the brakes. The pads arent over worn "I think" What could be this noise? Could it be a wheel bearing or something?
Old Aug 2, 2000 | 05:35 PM
KevMann's Avatar
New Member
Default Re: Check the backing plate.
There is a plate behind the rotor that may be rubbing the Rotor. Maybe this is the problem. It is easy to pull it away from the rotor.
Old Aug 3, 2000 | 10:51 AM
Nitrox's Avatar
New Member
Default Re: Chirping from right front wheel
I have the same problem but with the front left weel on my A4, my mechanic seems to think that its a warped rotor, but he's not too sure, it goes in on monday so I'll find out for shure then
Old Aug 4, 2000 | 05:29 PM
mel g's Avatar
Default diagnosis options
Try jacking car at the suspected wheel, then rotate the wheel by hand,and see what you can find out. Maybe there's something right there, obvious. Then try puttting the brake a little on while you turn wheel, see if there's anything you can see.
try to wobble the wheel, see how loose it is on the car( should be very little wobblw-mayber 1/16 inch back and forth or up and down.) that will check your wheel bearings. Good luck.
janbog
Q7 MK 1 Discussion
Jun 26, 2019 12:21 PM
Mr Brooks
Feb 11, 2019 07:55 AM
beejohn
Apr 15, 2005 12:41 PM
eltako
Audi 100 / A6 (C4 Platform)
Oct 26, 2004 05:37 PM
sidespar
May 1, 2004 08:14 AM
