Climate Control
Old Dec 27, 2000 | 03:43 PM
nowers's Avatar
Default Climate Control
The heater blower on my 89 200 QT comes on only if I rap upon it with a screwdriver handle (brushes are obviously sticking.) My Bently manual tells me to remove heater box and replace the "Fresh air Fan."
1. How hard is this job? Must I really remove the center console within the passenger compartment?
2. Should I fix the blower?
3. Where should I look for replacement at reasonable price?
Old Dec 27, 2000 | 07:23 PM
SteveAngry's Avatar
Default Re: Climate Control
Job is rather easy, but labor intensive. Alot of taking things apart and reassembling...4-6 hours of work depending on your mechanical ability. As far as my 88 5000(older brother of your 200)there was no need to remove the center console at all. Everything was accesable from the plenum cover under the hood...
Should you fix it? Yes. Keep in mind there have been stories of bad blower motors catching on fire...
For parts go to
audiquattroparts.com or
thepartsconnection.com
I know Blaufernugen(audiquattroparts.com)has blower motors for $99.00...TPC should also be competative....HTH
Steve Ankney
88 5000
Michigan
Old Dec 28, 2000 | 12:09 PM
SteveJ_in_TX's Avatar
This will help:
http://www.audifans.com/archives/1997/08/msg02239.html
I used them to replace the blower in my 87 TQW and they worked just fine.
WRT replacement motor sources, I bought mine at Autobahn Performance in Atlanta as it is local for me and very good prices. You may also want to contact Linda or Didi at Carlsen Audi in California as their prices are good as well.
Good luck!
-Steve Jensen
87 5kcstq
87 5kcstqw
zeems
Mar 23, 2006 09:20 PM
orangedawg
Nov 22, 2005 07:05 AM
cabriolh
Sep 28, 2004 03:25 PM
KaMaKaZieP -ALUMIN8-
Audi 100 / A6 (C4 Platform)
Jun 9, 2002 10:53 PM
