Knock sensor
Old Jun 20, 2001 | 01:08 PM
Robjared's Avatar
New Member
Default Knock sensor
Finally got result of diagnostic code on my 1988 Audi 90. Fuse was missing and this lead to not being about to read code. Mechanic says check engine light is going off due to knock sensor code. I have ordered one. What kind of problems would a bad knock sensor create? I did have excessive pinging before the timing was changed but also had reliability problems including startup problems. Now the mechanic has changed the timing again and he says startup is fine and car idles perfectly. All we need to do now is replace the knock sensor according to him. Does it sound like we're on the right path and is it OK to run the car for a few days before the sensor comes in from the dealer? BTW, The O2 sensor was just replaced too.
Old Jun 20, 2001 | 01:59 PM
ARK's Avatar
ARK
Default There are numerous knock sensor issues due to over-torqing them, connector corrosion, and ..........
intermittent wires internal to the harness between the sensor and the connector
gmtalike
13
Jun 18, 2015 08:24 PM
vtraudt
Mar 31, 2011 06:12 AM
Kahuna-Big
Dec 18, 2009 06:23 PM
valentine1
Nov 13, 2009 06:09 AM
WaggsA6
Oct 26, 2006 08:16 PM
