O2 sensor for '86 4KS
Be advised if you live in an area which does cold start emission checks, you car may not pass without the heated 02 sensor.
When the check engine light comes on, does the car go into a 'limp mode' or something that would explain the loss of power.
JD
I tried a few weeks ago without success although I didn't explain the problem very thoroughly when I posted. Maybe I will try again when I get some time.
As long as the car keeps 'correcting' itself I am not going to spend time and money tracking the problem down. However, I have a hole in my muffler so hopefully when I replace it, the light will go away for a while.
I read somewhere that if the oil pressure drops below a certain level, the light will come one. If there is an oil leak, or the oil viscosity is incorrect (Haynes recommends 20W50?!?!?) could this be causing the light to go on? I've only had the car for a couple of months now and I was surprised to see that grade of oil recommended. German cars sure are unique.
Jeff
I'll have to check that website out.
Thanks,
dB
