Power steering fluid equivalent
Old Sep 30, 2000 | 08:26 AM
MountainMan's Avatar
New Member
Default Power steering fluid equivalent
I have an '88 90 and the manual says to use "mineral hydraulic oil" or equivalent....what is and equivalent that's available at a parts store? The nearest dealer is 50 miles away.
Old Sep 30, 2000 | 02:08 PM
ChuckH's Avatar
Member
Default You need this magical (and expensive) stuff called Pentosin. There...
...are a couple different variations of Pentosin though and I can't remember which one is correct. I want to say it's Pentosin PS11 or something like that. Can someone confirm?
Regardless, i don't think the average Auto Parts stores carry it, and if you don't use it your system gets screwed. Do you have any independents near you?
Old Sep 30, 2000 | 02:48 PM
DaveN's Avatar
Junior Member
Default They do here in Boulder...
the can I have says Pentosin CHS 7.1, it is dino (although most of the can is in German, which I don't speak so I can't tell you alot more, nut the front of the can reads "Ol fur zentral hydraulische systeme", which shows how close English is to German). The 11S stuff is man-made, a warning, my can says not to mix them, but I think on an 88 it would be the dino.
Old Sep 30, 2000 | 06:02 PM
Les's Avatar
Les
New Member
Default Some suggestions
I was able to find Pentosin hydraulic fluid at many places. I got mine at O'Reilly's and I know Advanced Auto Parts carry them. If you can't find fluid anywhere near you, I do suggest you order some on-line. Blaufergnugen sells 'em at good prices. I also mixed the 7.1 with the 11. But I stick to 11 now. I think it works a lot better on my car and I it feels as though the wheels turn a lot more smoothly. It's also more stable under higher temperatures. Whatever you do, don't use regular power steering fluid. It'll put a lot of strain on your pump and your line.
Old Oct 1, 2000 | 05:37 PM
fabio's Avatar
New Member
Default Re: Some suggestions
CHF11S is what you need, basically an update of the 7S.
LarryJa
11
Apr 5, 2016 09:24 AM
Nvncibl
Jun 14, 2004 06:44 AM
2tu®bos1mission
Dec 12, 2003 04:44 PM
MichaelTM
11
Dec 4, 2002 02:45 PM
