Power Window Questions
In short, the cable is shot, and I need a new one. The problem it, you cannot buy just a cable, because to insert a new cable, you need to break the two leads that come out of the motor (the have springs on them, they are white, about 4 to 6 inches long, and then have a black sleath that runs to the window guide (long, metal, in the middle of the door) and conceals the cable. At this point, the cable is visible in the guide, and does the actual raising and lowering of the window.conceals the cable).
Here is the question (not a moment too soon!) Is there a place where I can buy a new cable (which I assume is steel) that has all the fixtures so I don't have to break needed parts? Could I possible take the cable (with needed parts) out from the driver rear window?
