Rotor Replacement
Old May 30, 2001 | 07:29 AM
BobG'95-90's Avatar
New Member
Default Rotor Replacement
Hi Guys:
I am changing the rototrs on my '95 90 this weekend. Are there any special things I need to know or is this pretty straight forward on these cars? I am putting on ATE Power disks - does anyone have experience with these? Also, how are the rotors mounted to the hub? Thanks for your help.
Bob
Old May 30, 2001 | 09:43 AM
audi/s/scott's Avatar
Default Return the rotors and get Zimmermans....
myself and many other people have had problems with the ATE's. I had them on my last car (95 90q) and they warped after several K miles. Wet weather performance sucked too. Follow the link to the A4 forum, I'm not the only one.
As for install it's easy, remove caliper (2 17mm bolts if i remember) and the rotor should come right off. It may be rusted on and a mallet may be needed to get it to come off. You'll need a large C clamp or brake tool to push the piston back in the caliper. I used the C clamp.
If anyone wants the old warped ones you can have them (still in basement).<ul><li><a href="https://forums.audiworld.com/a4/msgs/585834.phtml">https://forums.audiworld.com/a4/msgs/585834.phtml</a</li></ul>
Old May 30, 2001 | 11:30 AM
bmwslayer's Avatar
Junior Member
Default Re: Return the rotors and get Zimmermans....
i had ATE Atom Slotted rotors and Mintex pads in chicago..and the rotors and pads where toast in 6months time. i then put on Zimmermann rotors and Resma Gold racing pads and had them of for about a 1 1/2yrs. and love them...if u want great prices on these rotors and pads...contact randy at Midtex Audi& Porsche in Naparville, IL. 1630 904 5745 or u can look in the back of European Car mag. in the back and see his ad for his #888. tell randy Bimmerslayer sent you..he will hook u up..and my rotors are still in great condition and the pads put out very little dust..BMWSLYR
nurseman
Mar 20, 2004 07:19 PM
boogs
Dec 29, 2003 03:51 PM
KMU
Jul 22, 2003 08:34 AM
Craigito
Apr 17, 2003 07:45 AM
Duker90cs
Oct 15, 2001 05:24 PM
