Update....
Old Nov 28, 2000 | 01:34 PM
JMG_CT's Avatar
New Member
Default Update....
Updates on my 1986 5000CS turbo quattro:
1.) reverse light switch - replaced (NOT easy)
2.) brake light switch - replaced
3.) still has problem starting when cold
4.) center differential doesn't appear to be locking... I click the switch to position 1 and the light doesn't come on... also antilocks don't shut off (they're supposed to) anyone have any ideas on this one? vacuum servo? switch?
All in all the car is coming together... not bad for $1000... still needs front shocks, front right wheel bearing, cold start fixed, and now the center differential problem...
Old Nov 29, 2000 | 11:05 AM
97A6guy's Avatar
New Member
Default Re: Update....
My 4k had a problem with the cold-start sensor which is supposed to shoot fuel into the engine when cold. Never used quattro I or II - can't help you there, but switches can fail.
ABS on an 86? I thought that came about in 89. Oh well, make good friends with the junkyard man.
Two tips: never by a fuel pump from a junkyard. DO buy one when the pump starts to buzz The 5000 pumps are very easy to change, but sticking your hand in an ice cold gas tank sucks like you cannot believe. If you haven't guessed, they go often.
Davemc1948
Audi 100 / A6 (C4 Platform)
Oct 14, 2018 08:47 AM
applehugger
Apr 20, 2011 05:04 PM
old audi guy
Dec 21, 2003 05:06 AM
mint875000cstq
Nov 7, 2003 04:38 AM
budlight
Jul 7, 2003 11:30 AM
