UPDATE:
Old Aug 5, 2001 | 06:27 AM
Lutz's Avatar
Default UPDATE:
The car is a 1986 cs turbo
* it starts hot and cold with the first click
Yesterday, it ran fine for the first 20 minutes than came the first noticeable hesitation under acceleration that became increasingly worse. A bit more pedal pressure and it gave the impression of starvation.
*the fuel relay does not get hot
*I bridged the relay after the drive ... the pump does not make a healthy sound (various noise levels)
? would the pump weaken after 20 minutes of use - and act like this??
? The injector cooling fan - where is the thermo-switch (sensor) located??
Any help would greatly be appreciated.
Old Aug 5, 2001 | 01:21 PM
Todd W's Avatar
Junior Member
Default Injector cooling fan thermo switch
Is located on the heat shield around the wastegate, just off the back of the valve cover. It has 1 wire.
ludviks@online.no
Jul 22, 2018 07:20 AM
Jonny6am
Mar 25, 2014 09:11 AM
rogerryan
Oct 4, 2011 06:26 AM
bcart82
May 14, 2007 03:05 PM
DJ Springer
Misc. Models Discussion
Dec 29, 2000 07:03 AM
