Wierd idle
Old Jun 28, 2001 | 08:09 PM
Jaxon's Avatar
New Member
Default Wierd idle
The joys of Audi. My '89 200 QT will idle at 2-3,000 RPM then just as suddenly, settle down to normal idle. I've cleaned and replaced the ISV and checked for vacuum leaks, all to no avail. Any ideas?
Old Jun 29, 2001 | 08:03 AM
DaveN's Avatar
Junior Member
Default Check the idle switch also...
it is under the plastic cover on the throttle body.
Old Jun 29, 2001 | 08:31 AM
Style12v's Avatar
Junior Member
how old are you o2 sensors?
Old Jul 2, 2001 | 09:06 PM
Jaxon's Avatar
New Member
Default Re: how old are you o2 sensors?
Brand new. But O2 sensors are singular, right? Just one on the exhaust manifold.
Thanks...
Old Jul 3, 2001 | 12:45 AM
bucktwo's Avatar
New Member
Default Re: Check the idle switch also...
Just spent all my spare hours for the past month going through vacuum hoses and connections plus air sensor and throttle body plates which had loosened. Idle was last problem and found a wire crack at throttle body sensor. Peace at last and stable to boot.
paulpas
Aug 29, 2014 08:26 AM
German Driver
NY / NJ / CT Discussion
Feb 22, 2007 08:15 PM
vanhawk
Audi 100 / A6 (C4 Platform)
Nov 30, 2005 07:04 AM
djdc
Dec 24, 2004 12:16 AM
mau
Performance and Tuning
12
Oct 30, 2003 04:33 PM
