Schroth Quickfit Rallye 4 Harness (b6S4) install question:
There's interference between the molding and the outboard tail strap mounting. How do I configure the bracket before bolting and tightening to assure the molding fits properly?
Or is a pass-through slit cut in the molding necessary which I DO NOT want to do? :-(
Or am I having a brain fart here? :-)
Jeff W..what did you do?
Re: Schroth Quickfit Rallye 4 Harness (b6S4) install question:
<center><img src="http://www.smoe.org/jeffw/albums/car_harnesses-2005-06-28/IMG_4259.sized.jpg"></center><p>I think a slit is the only choice. The clip needs to be bolted to the seat belt spool, and there's no other way to get the tail exposed to the interior....
If you're worried about appearance or lease return, check w/ the parts dept on the price of that trim piece
THANX! Can you tell me where to 'pry' at the trim to remove it? I want to ...
inflict the least amount of distortion as I can so I don't screw it up. I want to get the belts in for LRP next month. Thanx again Jeff. :-)
An alternate is the Audi body shop, but Jeff is in the PC, shop is a 21 mi. drive. ;- )
Like the carpenter says, "measure twice, cut once".
