Any thoughts on upgrading to "bosch fusion platinum" spark plugs?
I've found very little difference in plugs
unless they are the wrong plugs. I've tried plats, coppers and iridiums...all the same performance. The lifetime is very directly related to price so its all a matter of how often you want to change them.
2nd - unless you significantly change what's going on inside the cylinder, plugs won't make...
...much of a difference. An example of a significant change would be going from 150HP to 300HP in a 1.8T. Even then, the difference will be because of the plug spec and not the plug brand or model.
PanTTher
02-06-2006 12:27 PM
How often should you replace spark plugs, and do worn spark plugs reduce fuel efficiency/performance
Alias Unknown
05-22-2004 07:36 AM
djnelsen
04-06-2002 05:21 PM
