Code 16795?
Please help if you can, I have a 98.5 2.8Q with 110k miles on it. A few months ago, my check engine light came on, and it has been on and off since.. (stays on for about 1-2 week, and off for 3 days, and repeat itself all over again)..
Can someone please help me on this matter..? I was told to check for vaccum lines.. but, i am not sure where to check.. also, i already did the factory recall thing, but, still CEL.
Here is the VAG reading:
Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
Readiness: 0000 0101
2) check your gas cap and make sure it is not cracked
3) did you have your fuel pump/ filter replaced?
4) could be a hose leak behind the O2 sensor
5) WHAT ARE YOU DOING DRIVING AROUND WITH A CEL THAT STAYS ON 1-2 WEEKS?!
to answer your questions:
1). no, i use mostly 91 gas
2). gas cap was replaced within 8 month
3). new fuel filter within 12 months
4). not sure......
5). well, that is why i am trying to figure out wha the problem is....
please help..
it seems like i need to check for "lose or crack" hoses and combination valve, before replacing the 2ndary airpump...
Can someone please post a picture or show me where is the combination valve?
I live and work close to San Jose/Sunnyvale,, please help Thanks!
-jjc
