Auto dimmed rearview mirror is not working...
Try posting this on the forum specific to your car and I bet you get some good responses
You don't mention model so it's tough to help but the first thing that needs to be checked is whether you have power at the mirror.
Good luck
Good luck
Re: I solved mine through replacement. If it's dead, that's the only solution.
Did you get the replacement from dealer? Is the instruction on owner's manual?
The car is 01. A6 2.7T.
Mine came from ECS Tuning, but you should check the dealer.
The install is very quick, so they may not charge you much to handle it.
If you decide to do it yourself, ECS tuning sells them, and you should also check with carson@riversideaudi.com
I found instructions by searching the archives.
bballfreak
9
04-14-2019 06:59 PM
