Performance and Tuning Discussion forum for various performance tuning techniques and questions
1.8L engine output
Old Apr 8, 2001 | 09:42 AM
john s's Avatar
Member
Default 1.8L engine output
<center><img src="http://im1.shutterfly.com/procserv?si=00002937301920010408033951855.JPG&cb=1 5066852&ph=59621&cr=0.0,0.0,1.0,1.0&r=0&p=1&pa=0.5 &b=1&bw=0.2&sa=0&ps=3&po=0&g=2.2&q=80&rx=644&ry=56 3"></center><p>Anyone here with a similar problem? Made a few posts on the TT site, but no answers. When I checked my engine a few weeks ago it was regulating to 265 Nm instead of the spec of 280. Now it's regulating to 257 Nm. Before the torque gets to the regulation speed range (2200 to 5500 rpm) the duty cycle on N75 is over 95% then it backs down to 60% as the engine speed rises. Boost is being regulated to 1.8 bar. With quick acceleration in the low gears I can get spikes to 2.1 to 2.2 bar (with torques in the 270's) but N75 quickly backs off on duty cycle and the boost drops.
Old Apr 8, 2001 | 01:51 PM
john s's Avatar
Member
Default Boost regulation
<center><img src="http://im1.shutterfly.com/procserv?si=00002937301920010408211708978.JPG&ps=0 &rx=640&ry=480"></center><p>Power is down because ECU is regulating it that way. Is this typical? Traveling is 6th gear, throttle closed, speed dropping. Open throttle slightly to maintain speed, 186 second point. WOT @ about 189 second point. Pressure builds, above 2200 rpm pressure is greater than command pressure. Wastegate is activated, takes almost 2 seconds. Pressure is held at command pressure. Torque is only 257 Nm, spec is 280 Nm.
Old Apr 10, 2001 | 10:26 PM
garrettUP's Avatar
New Member
Default Re: Boost regulation
i know this sounds pretty simple but have you checked for boost leaks? replace the DV yet? are you chipped?
Old Apr 11, 2001 | 08:46 AM
john s's Avatar
Member
yes, no, no
Old Apr 11, 2001 | 08:54 AM
xr4tic's Avatar
Have you tried resetting the ECU?
2.7Lturbo
16
Dec 20, 2010 03:31 PM
anothersilver
Aug 27, 2006 08:34 PM
JVA
Aug 24, 2003 02:47 PM
john s
Apr 8, 2001 01:00 PM
