1.8t+K04...what's the optimum core thickness for a FMIC?
Re: 1.8t+K04...what's the optimum core thickness for a FMIC?
The weight you cut by going with titanium is so small in the grand scheme, its not worth it. Al isn't that massive, and is cheaper than Ti...You won't offset adding a heavier IC by using Ti for your piping.
1.5" will be about the max you could do without any major surgery....
<center><img src="http://pictureposter.audiworld.com/21967/pa040001.jpg"></center><p>Unless you kept the IC core height down, and install it directly in front of the lower grilles. Then you can go 3.5-4", but have fun getting someone to make the pipes!
2" will fit with no problem
this will fill the gap of an S4 bumper
<img src="http://pictureposter.audiworld.com/8358/steeringline.jpg">
but the top/bottom design is "optimum"
<img src="http://pictureposter.audiworld.com/8358/yelfogs1.jpg">
At least 2"....
and no more than 2.5" for a K04. You don't want to get too crazy with the size. Stick with 2" piping.
I've got a 3" that will be going behind an S4 bumper. Initial measuring says it will fit, but I haven't actually tried to put it in yet. I'll get in there somehow
1.8T Boricua
05-17-2005 05:11 PM
markbradford
05-09-2003 07:05 AM
