5 bar FPR with MTM stage 2 and K04
I just put in a K04 and have the same MTM stage 2 software. Now that the temps are starting to get consistantly above 70F I'm holding about 25psi.
The local tuner that I get my software etc from says I don't need it but I'm starting to wonder if I would be safer to put on in.
MTM stage 3 software calls for 5 bar FPR.
Can't answer your question but I have a couple...
is your tuner Anderson Motorsport? And are they able to sell MTM's K04 programming separately, or are they like Hoppen and refuse to do that?
Whoa! 25 lbs? I've spiked at 21 and hold around 18.
I wonder what the difference is. FMIC? I don't have one, but am putting on the EVOMS unit in a couple weeks. Do you think that'll make a difference?
I'm not sure what you mean about seperate programming
but as far as getting the programming from Anderson I will have to get the MTM downpipe and hiflow cat. I guess MTM was getting blamed for turbo problems or other problems when people were using equipment other than MTM.
It sounds like you need almost everything MTM to get the software.
programming = software...
so yeah, I wanted to get the components for a K04 kit separately, then send my ECU to Anderson for them to chip w/ MTM's K04 software. From your reply it sounds like they don't do that... bummer.
Before I had the new turbo I would hold at 21 and taper from there
It could be the year of your car. What year is it? Mine is a '97 so I have the bigger injectors.
Angelo Pappas
01-14-2003 05:46 PM
Tbandido
Rocky Mountain Discussion
01-02-2003 11:20 AM
