A4 1.8T Transplant into Audi 80Q or 4KQ?
Hello all.
I am considering the purchase of a used Audi 80Q or a used Audi 4KQ. Here is my comparison table between them:
80Q 4KQ
3.55 3.60 - 1st
2.11 2.13 - 2nd
1.30 1.46 - 3rd
0.94 1.07 - 4th
0.79 0.83 - 5th
4.11 4.11 - final
3.2 3.11 - turns (lock-to-lock)
33.8 34.8 - turning circle
not MacP MacP - MacPherson struts
F/R lower CAs no F/R lower CAs - control arms
9.6" rear 7.9" rear - rear brakes
3.7 quarts oil 4.0 quarts oil - oil
8.5 quarts cool 8.45 quarts cool - cooling
99.9" 99.4" - wheelbase
0.7" 0.4" - delta track
176.3" 176.6" - length
66.7" 66.4" - width
54.8" 54.3" - height
5.0" 4.9" - clearance
2904 # 2824 # - weight
TORSEN Center Lockup Control - center diff
Auto Rear Lockup Control - rear diff
Stabilizer Rear No Stabilizer - stabilizer bar
Ind. Rear 4-Wheel Ind. - suspension type
Here is my listing of advantages for either car:
Audi 80Q
closer-ratio transmission
lower 3rd-5th gears
smaller turning circle
front/rear lower control arms
9.6" solid rear discs
8.5 quarts coolant
rear stabilizer bars
TORSEN center differential
Auto Rear Differential Lock
176.3" length
Audi 4KQ
higher 1st-2nd gears
smaller turns (lock-to-lock)
MacPherson struts
4.0 quarts oil
2824 pounds
99.4" wheelbase
0.4" delta track
66.4" width
54.3" height
4.9" clearance
By the way, I do not care about the power produced by the I-5. I plan on transplanting an A4 I-4 1.8T engine into whichever car I decide to purchase.
The thing that scares me about the Audi 4KQ is the manual operation of differential locking; it is all automatic on the Audi 80Q.
Which car would you recommend for the transplant?
Thank you,
Tim.
80Q 4KQ
3.55 3.60 - 1st
2.11 2.13 - 2nd
1.30 1.46 - 3rd
0.94 1.07 - 4th
0.79 0.83 - 5th
4.11 4.11 - final
66.7" 66.4" - width
Audi 80Q
lower 3rd-5th gears
8.5 quarts coolant
176.3" length
Audi 4KQ
MacPherson struts
4.0 quarts oil
2824 pounds
99.4" wheelbase
0.4" delta track
66.4" width
54.3" height
4.9" clearance
Thank you,
Tim.
Re: A4 1.8T Transplant into Audi 80Q or 4KQ?
I hope you realize the 1.8T swap is not an easy thing to accomplish with earlier model Audis. I know one fellow who has swapped a 1.8T into an 80 FWD 4 cylinder. It cost him over $10k USD to do this. Tons of custom work is required to make this work. Subframe modifications, custom pilot bearing for the trans, clutch issues, wiring, and so much more
toast_S4
Audi Original "S" Cars
05-19-2008 07:12 AM
CK:1.8T+Rabbitâ„¢
01-03-2006 01:30 PM
