A8 front rotor setup on A4
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/brake%20compare%201.JPG"></center><p>I picked up a pair of A8 rotors and TT caliper brackets per the FAQ I was recently made aware of
in here.
Here is a photo of a stock A4 rotor and bracket and the A8/TT parts.
I dont plan to install these until sometime this spring but I did fit one up to be sure it is usable. Goes in easy and does clear the 16" A4 stock sport wheel. The FAQ says this also works on the A6.
FYI, the A8 rotor weighs 2.5 pounds more than the A4.
in here.
It's a good cost effective setup
Have been using it for 3 months now. I am using EBC greens but will be changing to Porterfield R4s because the grees squeel way to much no matter what "fix" if applied. They stop great however both in the dry and in the wet. I have not, nor do I plan to do any "serious" track work.
Jeff Davison
BTW, don't forget to install stainless brake lines. Worth the money.
Jeff Davison
So, is there supposed to be a noticable difference in braking performance?
Please don't take offense. I'm just wondering why someone would want to spend the money on this when to me doesn't seem to be worth the price in performance?
Re: So, is there supposed to be a noticable difference in braking performance?
I saw about 5ft 60-0 reduction using my G-Tech with my G-Force tires. Your mileage may vary.<ul><li><a href="http://pictureposter.audiworld.com/AudiWorldPics/leszekm/brakefaq.html">My brake FAQ</a></li></ul>
I will find out, but should be similar to 10"-11" upgrades on Passat
I guess it depends on your definition of performance. If you need more braking for racing, then you should spend the 3-5 times this "kit" for multi-piston calipers, drilled/slotted rotors.
If you just want to take advantage of the potential braking improvements that come with bigger rubber (I use 225/40x18 Pilot Sports except in winter) then the added leverage of the larger rotor is the least expensive way to get there. I found that on a clean dry road, even with the EBC Greens (mine have never rattled or squealed by the way) I do not have enough brake power to lock up these tires in a straight line stop. That means I am leaving a few feet of stopping distance behind me in a panic situation. Some day I may wish I had it.
Yep, "stainless" lines are on my list too.
Did you crosshatch the rotors before installing them?
I noticed they do not come that way. Both EBC and Audi recommends this to improve pad seating and reduce the tendency for (any) pads to squeal.
Sloooo4esT
Audi Original "S" Cars
12
03-16-2005 11:38 AM
audia4sport
12-02-2002 04:05 PM
