aftermarket knock detection system
<center><img src="http://www.jegs.com/photos/1218964.jpg"></center><p>i know that some fab work will be needed.
any thoughts?<ul><li><a href="http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=26719&prmenbr=76">jegs.com</a></li></ul>
I think there are only two....
one between 1 and 2 and the other between 3 and 4.
Since two cylinders don't fire at the same time, you can have one knock sensor for two cylinders and still know which one is knocking.
there was a discussion on VWvortex about why this isn't possible :(
the voltage is just the volume/loudness of the knock...........
the ECU "listens" through the knock sensor for a specific frequency, (iirc 5-8khz) and detirmines a knock from backround noise through a filtering system. i would have to tap into the ECU after this system, (if even possible) to get a signal line...PITA! ;P
