Aftermarket tachs. What and where did you wire it to? I am using a SPA wired into the
wh/gn on the coil amp, I have used this before for a 3 stage shift light with good success. However my tach is idling right and the shift lights appear accurate, but the needle crashes back to 0 after 4500rpm's. Tach? Wiring? I'm looking for another angle.
I use the Green/blue tach wire that is on the back of the cluster in the first plug
nearest the drivers door for my shift light. But this is on a A4 1.8t. Been using this for my shift light for almost 2 years. BTW which 3 stage shift light are you using.
SPA which includes a digital telltale, same as my current tach...what kind of tach are you using
and what did you have to make it see? The SPA by being hooked to the coil amp had to be programed to see a one cyl. engine. It's quite a versatile tach., it can go from 1 to 16 cyl. engines. I will try the gr/bl to see if it makes a difference, but I would like to what tach you are using.
On your 98 the wire on the back of the cluster is just solid green.
I just use a Autometer shift light for drag racing. But I really dont use it anymore for my old setup since I went by sound/feel anyway. I might have to use it again but I will need to get a new set of shift pill since I will be shifting at 8k-8500 rpms with the 2.0 liter motor.
BIG NIPPER
06-19-2002 11:19 AM
S4NoRice
12-13-2001 12:41 PM
Totalled SuperChargeA4
05-02-2001 12:42 PM
