Anyone consider anything other than the Turbo XS bpv as the top performer?
Generally speaking the bang for the buck option is the TT BPV, but for all out, reliable performance I think the turbo xs bpv is considered to be the best.
Bailey and Forge have shown to develop problems...been there done that.
I am BPV shopping, and curious if there is another valve out there that I should be considering.
thanks
-Will
thanks
-Will
I have been using the bosch porsche valve that EVO sells for $89.
It had lasted a pretty long time and I do run a lot of boost. Maybe I just got lucky or I am pushing my luck with it. I usually carry a back up BPV when I go to the races just in case it does break. Juan has my TurboXS on his GTI right now and loves it.
Because at the time I was using it I had the FMIC on and noticed a
spot where the valve was not closing. This gave caused a small lag when drag racing. Juan fixed that problem by putting in more spacers, I guess the spring was just weak from all my racing.
That $89 bpv is the same one that's on the 225 hp TT's, right?
the pn on the 225 tt bpv ends in 710N, and costs $35 at the audi dealership. It's what a lot of the guys I know use...has a stronger diaphram for the added pressure of the 225 hp engine.
No, the one from EVO is for a 996 porsche.
I tested a TT valve and it did not hold enough boost for me. The evo valve has held great even with me pushing 1.8 bar(26psi) with the PES T28 kit.
cut 'em open, the 710N has a thicker diaphram, and a stronger spring.
test with the vacuum & the 996 tt bpv will have a 15 lb spring(?) & I think the 710N has a 17 lb one(?). the differences in performance are extremely close, not worth bickering about, but the $ difference makes the choice clear to me. Plus, they're both made by the same company, and the part numbers are nearly identical.
Now why would I cut mine open if it has worked for over a year on a car that makes 335-350 hp
and help firm on 1.8 bar of boost on a T28. I tested the TT valve on a car and it would not hold more then 15psi on a K03. Maybe it was bad straight from the dealer I dont know. But if your going to complain about the difference between $22 and $89 there might be a problem. One valve is made for a car that makes 225 hp while the other one is made for a car that puts out over 400 hp.
