Performance and Tuning Discussion forum for various performance tuning techniques and questions
Big break question.
Old Aug 21, 2003 | 02:27 PM
Fraser@PNS now w/S6's Avatar
Default Big break question.
What is the minimum gap that I should have between the caliper and the wheel? Or if it fits it it ok?
Old Aug 21, 2003 | 07:00 PM
WYSIWYG's Avatar
paging Mike O. =) your department
Old Aug 21, 2003 | 11:43 PM
Johnny Bravo's Avatar
Default Ive seen a ~2mm Gap when cold between the calliper and wheel spoke
SSR Gt3's. It was smaller when hot, just enough to slip a dollar through. But then again ive seen setups with more gap with series signs of interference ( tri sport egineering, with mazda protoge's (sp?) alcon calipers and SSR comp wheels).
Old Aug 22, 2003 | 05:58 AM
SKS's Avatar
SKS
Junior Member
Default With good wheels a business card will suffice, all of the others better to keep at about
1/8th". If it's just touching you can grind some off the calipers as they are quite thick.
Old Aug 22, 2003 | 06:20 AM
Mike O.'s Avatar
Default 1.5mm was too little for me.
Bearings will allow for that much deflection and cause interference with the wheel. I know for a fact that 1.5mm didn't cut it.
I wouldn't go any lower than 5mm myself.
Mike O.
Old Aug 22, 2003 | 06:34 AM
cuatrokoop's Avatar
Default Re: With good wheels a business card will suffice, all of the others better to keep at about
Yup, I've actually had no problems with either set of ATS wheels I have on the Coupe fitting over the 993's. The 16" wheel is a dime's width away from the caliper radially, whereas the the 17" wheel is extremely close axially. No marks on the caliper body from the wheels...
Old Aug 22, 2003 | 07:01 AM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Re: 5mm? 2.5mm is plenty of room! ;O)
<center><img src="http://home.ec.rr.com/miktip/Alcons22.jpg"></center><p>
Old Aug 24, 2003 | 10:46 AM
Brent V's Avatar
Default I've got about 2mm between my calipers and wheels
never had a problem with deflection, here's a pic:
<a href="http://www.vandussen.com/audi/08040010.JPG">Side Shot</a>
<a href="http://www.vandussen.com/audi/08040011.JPG">Close Up</a>
Wheels are 17x8 BBS RK's, calipers are Porsche 996 on OEM S4 Rotors. No wheel spacers.
 Michael S. Palmer
Old Aug 26, 2003 | 03:21 PM
SD3.0A4Q's Avatar
New Member
Hey Mike O., I see in one of your pictures there is a plastic cap on your jack head. Where did you get that cap? I am worried about using a roll away jack on my car, that cap looks like the solution.
s4wood
Aug 24, 2005 02:31 PM
April
15
Mar 30, 2004 03:27 PM
pure/n/simple
Auto Detailing Discussion
Nov 15, 2002 08:54 AM
April
9
Jun 20, 2002 08:09 AM
Airmoe
May 4, 2001 12:41 AM
