Performance and Tuning Discussion forum for various performance tuning techniques and questions
Bleeding air from cooling system
Old May 15, 2003 | 08:08 PM
S4_downunder's Avatar
New Member
Default Bleeding air from cooling system
Was wondering what the procedure was to bleed all air left in the cooling system after doing a full coolant flush
AEB 1.8T engine
Thanks
Old May 15, 2003 | 09:50 PM
WYSIWYG's Avatar
Default 2 heater hoses (covered by an accordion thing) to right of the battery
left hose... slide the clamp away, pull the hose until its barely clinging on the pipe - the tiny hole on top of this hose should open up.
what i do is fill the tank and squeeze(pumping) on the radiator hose until coolant squirts out of the tiny hole (a foot up in the air should do). you can also lift the semi filled tank until coolant overflows/squirts from the hole.
i only did this when i had over heating problems, usually i just fill and rev.
Harddrive2000
Jan 17, 2011 09:26 AM
Astral
Nov 3, 2010 06:03 AM
montic
Oct 11, 2005 08:28 PM
talltorontoguy
12v V6 Discussion
Nov 15, 2004 11:40 PM
theaudiguy
Mar 7, 2004 11:10 PM
