Calling audi2ptzero....
It'll be mated with the t3/t4e, with a new hi flow cat, and the afc to dial the fuel, with a wideband 02 sensor kit to monitor the curve. Will upgrade the injectors to 450cc when I get ready for it, too.
The kit is from eurospecsport.com, right? $2500?
Am I missing any important steps? I'd like this one to stay together ;-)
Bwahahaha!~
Ryan that has the 2.0 liter and PES T28 kit also has the ESS motor which PES had built for him.
My motor cost me around $10K in parts and labor including a brand new AEB head that was ported to have max flow. This was done out of my stock ATW block and I paid to have the block checked to see what the max bore was that we could do on it.
IMHO it's overpriced.
A 2.0 forged/triggered crank from them is $650 (I bet you could find one used for less)
The stock rods are plenty beefy, they can be conditioned/balanced and fitted with ARP rod bolts for about $325.
Rod and Main bearings are $75.00
JE Forged pistons, made to your specs, are $550
The Eurospec pistons are only 82mm, I'd go at least 82.5mm, maybe even 83mm. Plus they're made for 8.5:1 compression, which is quite a bit lower than the stock 9.5:1
For $1600 you'll have everything the kit has, and if you want to go all out, you could get the Carillo rods for $1338 in place of reusing the stock rods, and have about $2600 invested.
Also keep in mind that having the block machined, and rotating assembly balanced (flywheel, crank, rods, pistons, pulley) will set you back another $700 or so.
FWIW, my franken-motor cost me roughly $4300 to build, not including all the turbo stuff. It's all the little things that add up. Check my 2.0 conversion page for my "what I've spent" list.
JE sells 82.5mm 8.5:1 pistons for our motor so it is not take too long to get.
I don't think they keep them in stock, they just make them as the order comes in, so it shouldn't take any longer to get them made to your specs.
I personally prefer a 9.0:1 compression ratio for a motor that sees a lot of street time. I think it's one of the reasons I see 15psi by 2800RPM.
Aren't your pistons 83.5mm?
Good Luck
