Can anyone help me interpret some VAG logs from my new KO4?
I logged blocks 002, 003, 012, and 031, WOT in 3rd tonight. Looks like I am running a bit lean in the upper RPMs, and I'd like to know how the MAF readings look. I don't really know what to compare them to.
The kit is a KO4, Ed M's old chip running the stock 4bar FPR and 260cc injectors.
Is running lean going to harm anything? I will email all the logs to anyone who is willing to take a look.
And here are a few more concerns, every few times I start up, and occaiosonaly while driving, I catch a whif of gas coming through the A/C.
And finally, I put in a new ECU, and the code the VAG reads is slightly different. The old one was 1.8L R4/5VT MOTR HS D07, and the new one says 1.8L R4/5VT MOTR HS D00. Anyone know the differnce between D00 and D07? Both are ECU code 8D0 907 557 P. Thanks.
Are you sure those are 260cc injectors?
The ndbw comes with 240's and the dbw comes with 270's. You can use a standard ndbw K04 chip with 270's and a 4 bar or the stock 240's with a 5 bar?
Not sure what those ECU codes mean, but you might want to check to see if the soft codes are different on each ecu.
If you want you can email me the logs and I can take a look at them. You might also want to try putting in a 5 bar fpr, but only do that if your 02 readings on block 031 are below .80
not 100% sure, i should have had them cleaned and flow tested
i found out a little too late about a shop near me that cleans and flow tests injectors. Thanks mike, i will email you the logs.
What is the danger in running a little bit lean?
my MAF readings on a k03, 1 bar chip. clogged airbox.
<center><img src="http://pictureposter.audiworld.com/143/vagplot-2.jpg"></center><p>max possible maf reading is about 180g/s i believe. most people get ~170g/s at wot.
as you can see i was waaay low.
thanks, looks like my MAF is ok, here is my block 002 log
Engine Engine Fuel Injectors Air
Speed Load Average Time Mass Flow
/min ms ms g/s
2800 10.6 16.32 93.26
2880 11.7 16.32 108.89
3080 12.15 16.32 119.72
3240 11.8 16.32 122.36
3400 11.05 16.32 119.17
3520 11.35 16.32 128.61
3680 11.2 16.32 131.59
3840 11 16.32 134.23
3960 10.7 16.32 135.76
4120 10.9 16.32 142.36
4240 10.85 16.32 146.81
4400 10.85 16.32 151.94
4520 10.75 16.32 155.28
4680 10.9 16.32 163.06
4800 10.9 16.32 166.87
4920 10.85 16.32 169.51
5040 10.8 16.32 173.54
5160 10.9 16.32 179.58
5280 10.65 16.32 179.44
5400 10.6 16.32 182.29
5480 10.55 16.32 184.93
5560 10.5 16.32 186.04
5680 10.35 16.32 187.36
5760 10.2 16.32 186.87
5800 10.1 16.32 187.22
5920 9.9 16.32 186.46
5960 9.8 16.32 185.83
6080 9.65 16.32 186.39
6120 9.55 16.32 185.56
6200 9.45 16.32 186.67
6240 9.35 16.32 186.39
6320 9.2 16.32 185.97
6360 9.15 16.32 185.69
6440 9 16.32 184.65
6480 8.95 16.32 185.21
6560 8.85 16.32 185.14
6600 8.8 16.32 185.14
6680 8.75 16.32 185.14
6720 8.7 16.32 185.97
6800 8.6 16.32 185.97
6840 8.55 16.32 186.11
6880 8.5 16.32 186.04
6880 8.45 16.32 185.42
6920 8.4 16.32 185.69
6600 0.7 1.47 15.9
6080 0.75 0 14.65
5520 0.8 0 14.17
4960 0.75 0 12.15
4440 0.75 0 10.83
a little hard to read on here but the MAF reading look ok.
/min ms ms g/s
6440 9 16.32 184.65
6600 0.7 1.47 15.9
6080 0.75 0 14.65
5520 0.8 0 14.17
4960 0.75 0 12.15
4440 0.75 0 10.83
Block 003
Engine Air Throttle Ignition
Speed Mass Flow Angle Timing
/min g/s ° °
2840 100.42 86.8 -9
2960 105.14 86.8 -9.8
3120 115.97 86.8 -9.8
3280 126.39 86.8 -12
3440 123.26 86.8 -12
3560 126.39 86.8 -12
3720 133.47 86.8 -14.3
3880 135.76 86.8 -17.3
4000 140.28 86.8 -18
4160 141.39 86.8 -18
4320 148.61 86.8 -18
4440 153.47 86.8 -18.8
4600 160.14 86.8 -15
4720 163.47 86.8 -12
4840 165.76 86.8 -17.3
5000 171.04 86.8 -14.3
5080 178.19 86.8 -13.5
5240 179.03 86.8 -12.8
5320 180.56 86.4 -12
5440 184.65 86.8 -9.8
5520 185 86.8 -12
5640 186.39 86.8 -11.3
5720 187.01 86.4 -11.3
5840 187.78 86.8 -10.5
5920 186.59 86.8 -10.5
5960 185.48 86.8 -10.5
6040 185.69 86.8 -9.8
6120 185.21 86.8 -7.5
6200 184.93 86.8 -9.8
6240 186.04 86.8 -9
6320 185 86.8 -8.3
6360 184.79 86.8 -8.3
6440 184.93 86.8 -11.3
6520 184.31 86.4 -9
6560 184.51 86.8 -12
6600 184.51 86.8 -12
6720 184.86 86.4 -12
6760 185.42 86.8 -12
6800 185.62 86.4 -12
6840 185 86.4 -11.3
6920 185.34 86.4 -9
6960 185.76 86.4 -11.3
7000 185.34 77.7 -11.3
6600 13.4 15.6 -34.5
/min g/s ° °
2840 100.42 86.8 -9
5520 185 86.8 -12
6240 186.04 86.8 -9
6320 185 86.8 -8.3
6520 184.31 86.4 -9
6840 185 86.4 -11.3
6920 185.34 86.4 -9
Block 031
O2 Sens Bef TWC
Voltage
V
0.64
0.815
0.77
0.765
0.82
0.835
0.83
0.83
0.83
0.825
0.825
0.83
0.83
0.835
0.835
0.84
0.845
0.845
0.835
0.825
0.82
0.815
0.8
0.795
0.795
0.79
0.775
0.785
0.78
0.775
0.775
0.775
0.765
0.765
0.765
0.76
0.765
0.765
0.765
0.765
0.765
0.765
0.765
0.76
0.75
0.76
0.76
0.76
0.76
0.755
0.745
0.755
0.775
0.025
0.02
0.02
Voltage
V
0.64
0.815
0.77
0.765
0.82
0.835
0.83
0.83
0.83
0.825
0.825
0.83
0.83
0.835
0.835
0.84
0.845
0.845
0.835
0.825
0.82
0.815
0.8
0.795
0.795
0.79
0.775
0.785
0.78
0.775
0.775
0.775
0.765
0.765
0.765
0.76
0.765
0.765
0.765
0.765
0.765
0.765
0.765
0.76
0.75
0.76
0.76
0.76
0.76
0.755
0.745
0.755
0.775
0.025
0.02
0.02
