Compression question...
Tricky part is getting it w/ the valves closed and at TDC.
You can pull the cap off the dist, if ya got one, and watch to see it line up with the cylinder you are testing.
Also no distributor cap since early 90's, but there are marks on the cam gear and bottom pulley of the 1.8T
A lot depends on the valves and how the rings are gapped. On our old 1 cylinder race motors we would open the gap on the oil scraper, and #2 ring so they were real wide, then heat them and compress them into the groove. Effectively it was like they weren't there. Then on the top ring we'd make it as tight as we could, depending on the brand of ring, just so it wouldn't crack. Super tight seal, with minimum friction.
But back to the topic, 140 all round should be fine.
Nifty trick you got there though. Maybe I can try something if I rebuilt the bottom end. Less friction sounds good
For a bleed down, 125 psi should be fine, you want to be checking for leaks.
Remember in a bug, you were dealing with an air cooled motor too. A lot of expansion and contraction, those rings were sloppy as anything. Popping the jugs on and off was a family night in the backyard.
