Cylinder head porting work...who does it?
I'm looking for someone who can do porting & polishing work on my S4 cylinder heads. Has anyone else done this yet? Can you recommend a good shop? I'm doing the porting on my intake manifold myself, but I don't want to tackle the cylinder heads (which are coming off this weekend, BTW).
find someone locally
i searched "audi racing" thru this site and found very experienced racing mechanics and teams - in my own town!<ul><li><a href="http://www.zip2.com">http://www.zip2.com</a</li></ul>
Find someone with Flowbench, look here...
I recommend that you find someone with a flowbench that tests his own work before and after. Go to the following URL to find someone in your area.
Paul Cormier
Director of Information Services
SuperFlow Corporation<ul><li><a href="http://www.superflow.com/superflow-it/superflow-it-locate.htm">SuperFlow Flowbench Owner Locator</a></li></ul>
Paul Cormier
Flowbench (as pcormier says) is manditory!!!
From the numbers I've seen the head flows just fine with port/gasket matching (based on the A4 design). The stock cam lift is the limiting factor (upstream of that tiny turbo and exhaust). Has schrick come out with a cam yet?
It is literally impossible to do this right without a proper flow bench.
Scott W
03-26-2001 06:35 AM
LCP
09-24-1999 06:48 AM
