Does anyone know how much psi is lost on stock 1.8T intercooler... say at about 12psi of boost? ...
How about TAP's sport intercooler? Should the difference in psi be proportional to increase in boost? Thanks much!
I don't remember the numbers, but go to europeanspeed.com....
they did some work with a large front-mount IC that also retained the stock side-mount IC. The loss in pressure was very minimal and I don't think you'll have a problem with the TAP sport IC, but personally I'd go with a larger front-mount for looks and performance<ul><li><a href="http://www.europeanspeed.com">http://www.europeanspeed.com</a</li></ul>
If the intercooler "lost" pressure, wouldn't....
..it flow the other way and make your turbo spin backwards ? You'd have 1 forward and 5 reverse gears. Or is this some kind of trick PV = nRT question ?
No, I think he means that when the intercooler cools air a little bit of pressure is lost...
when you cool a gas the molecules "hug" each other, causing a slight pressure loss
NOLAN5162
04-08-2004 04:37 PM
S4Play
08-17-2002 07:40 PM
Lightweight-USPowah
13
07-12-2002 07:02 PM
pikachu
04-10-2000 05:15 AM
