Followup on V6 oil cooler install on the 1.8T......
Previous posts I showed install pics, but didn't see any real cooler temps other than the oil warmed up much quicker.
Today, I had the opportunity to run it at Summit point, and I also checked with other 1.8T drivers to compare. My temps never went over 225, yet everyone I talked to was hitting 250. Success.
yes, the S4 oil cooler. Uses the bigger "J" filter, while the 1.8T uses the "561B"......
Either filter can be used, I used the bigger one since more oil would contribute to lower temps, and larger filter would have more filtering/increased cooling surfaces, although insignificant.
turbo510
08-18-2011 04:20 PM
LEH82
19
05-18-2008 08:46 PM
ex-quattro PETE
03-08-2003 08:24 AM
If I drain all of my oil out from my 1.8T, then unscrew the oil filter, will it pour out of the hole
Maddog
02-27-2002 05:15 PM
Kawika
04-21-2001 04:25 PM
