Forged Rods (Integrated Engineering) 1.8T 19mm Pin and 20mm pin Kits
<center><img src="http://www.42draftdesigns.com/images/dealers/sms.jpg"></center><p>All Items Include Free Ground Shipping in the lower 48 states.
All International order will pay actual frieght.
Integrated Engineering 19mm Pin Forged Rods
$380.00 Shipped (Comes with Rod Bearings)
Integrated Engineering 20mm Pin Forged Rods
$350.00 Shipped (Comes with Rod Bearings)
Integrated Engineering 19mm Pin Forged Rods,
Head Set, Head Bolts, Rod bearings and piston rings.
$580.00 Shipped
Rings and rod bearings
$450.00 Shipped
Complete rebuild kit for Forged Rod install for the 1.8T 19MM Pins Pistons. Less the Oil Pump. Add $100.00 for Oil Pump. This Kit includes 1 Set of 19mm pin Forged IE Rods, 1 Head Set, 1 Set of Rod Bearings (with the tangs for the redesigned IE rods), 1 set of Main bearings, 1 set of OE Head Bolts, 1 Front Main Seal, 1 Rear Main Seal (Not Pictured), 1 set of Standard size Thrust Washers, 1 tube of Oil Pan Gasket Sealer and 1 set of Standard size Piston Rings. FREE SHIPPING TO THE US. ALL INTERNATIONAL ORDERS ARE PAID VIA PAYPAL OR WIRES TRANSFERS. ADD $100.00 DOLLARS FOR OIL PUMP. ADD $225.00 FOR TIMING BELT KIT W/ INTERNAL WATER PUMP
799.00 Shipped
Features:
2 Piece Forgings from Vacuum Drawn 4340 Chrome Moly Steel Multi Stage Heat Treat for maximum strength, dimensional stability, and fatigue life. Fully Machined and Shot Peened H beam Design Tolerances as tight as .0003 ground on Sunnen brand equipment Standard ARP2000 Rod Bolts Computer Optimized Design Magnaflux Inspected Dimensionally Inspected Packed in balanced sets +/- 1 gram. All this at a price point that yields market leading value Dimensions 144mm Center to Center 19mm or 20mm Wrist pin 3/8 ARP 2000 Rod Bolts.<ul><li><a href="http://estore.websitepros.com/1936008/Categories.bok?category=Integrated+Engineering">ht tp://estore.websitepros.com/1936008/Categories.bok?category=Integrated+Engineering</a</li></ul>
$580.00 Shipped
$450.00 Shipped
799.00 Shipped
Features:
SMS Performance
12-18-2008 02:48 AM
SMS Performance
12-12-2008 12:19 PM
SMS Performance
1.8T Discussion
12-08-2008 09:41 PM
Ghostfire
03-08-2004 11:24 AM
18t, 19, 20, 20mm, complete, engineering, engineerings, install, integrated, kit, makes, mm, rebuild, rods, sms
