Performance and Tuning Discussion forum for various performance tuning techniques and questions
Help with a code: 17536
Old Jul 5, 2005 | 07:32 PM
Audone's Avatar
Junior Member
Default Help with a code: 17536
<center><img src="http://pictureposter.audiworld.com/19251/imgp0249.jpg"></center><p>I didnt write down the whole explanation, but something about a bank being too lean..
Lately I have had problems when I am starting up my car.. I have to let it idle for a few mintues before driving, and even then it sometimes stalls. It also seems to take forever to build up boost.
Oh, its a 98 1.8T A4 Stage 3 with the usual supporting mods
Pic for views!
Old Jul 5, 2005 | 09:48 PM
a_o_smith's Avatar
Default Long Term Fuel Trim mult.,Bank1 System too Lean
what do your o2 sensor #'s look like
Old Jul 6, 2005 | 04:38 AM
Audone's Avatar
Junior Member
I will take a look at them tonight...
Old Jul 6, 2005 | 06:40 AM
Audi2ptzero's Avatar
Elder Member
also check maf readings.
Old Jul 6, 2005 | 12:39 PM
PD Performance's Avatar
Junior Member
Default check measuring block 032
That will give you an idea of where to look. If its way + in the first field its at idle so that means a vacum leak. If its + in the second field then its most likely a MAF..
The slow to build boost could be from the bad maf on a cable throttle 1.8t, or a boost leak, however a boost leak usually would be rich.
Old Jul 6, 2005 | 07:00 PM
Audone's Avatar
Junior Member
Default OK, I logged # 1, 2 and 15 (saw misfires)
Here are the results.. Any help is appreicated,as I dont really know how to read these things, or know what to look for. On a quick look over, i didnt notice any vacuum hose leaks, but it was a quick glance, and the engine was warm..
Wednesday,06,July,2005,16:59:27
8D0 907 557 P ,,1.8L R4/5VT MOTR HS D07,
,Group A:,'002,,,,Group B:,'001,,,,Group C:,'015
,,Engine,Engine,Fuel Injectors,Air,,Engine,Coolant,O2 Sensor,Adjustment,,Misfires
Harmful,Misfires Harmful,Misfires Harmful,Misfire
,TIME,Speed,Load,Average Time,Mass
Flow,TIME,Speed,Temperature,Control,Conditions,TIM E,to Emiss Cyl 1,to Emiss Cyl 2,to
Emiss Cyl 3,Recog
MARKER,STAMP, /min, ms, ms, g/s,STAMP, /min,°C,%,,STAMP,,,,
,0.47,3240,4.10,7.23,59.93,0.74,3320,82.5,0.0, 000001,0.21,0,0,0,Enabled
,1.26,3480,5.00,9.34,78.26,1.53,3560,82.5,0.0, 000001,1.00,0,0,0,Enabled
,2.07,3760,6.15,12.29,103.54,2.34,3840,82.5,0.0, 000001,1.80,0,0,0,Enabled
,2.89,4040,6.80,12.93,123.40,3.16,4160,82.5,0.0, 000001,2.61,0,0,0,Enabled
,3.70,4400,6.80,13.06,135.07,3.97,4520,82.5,0.0, 000001,3.43,0,0,0,Enabled
,4.52,4760,6.85,13.63,146.87,4.80,4840,82.5,0.0, 000001,4.24,0,0,0,Enabled
,5.35,5080,6.85,14.02,155.62,5.62,5200,82.5,0.0, 000001,5.08,0,0,0,Enabled
,6.21,5400,6.55,14.53,158.96,6.48,5480,82.5,0.0, 000001,5.92,0,0,0,Enabled
,7.04,5720,6.35,14.98,163.96,7.30,5760,82.5,0.0, 000001,6.77,0,0,0,Enabled
,7.83,5960,5.70,13.18,152.64,8.09,6040,82.5,0.0, 000001,7.56,0,0,0,Enabled
,8.62,6160,5.40,12.54,150.34,8.88,6240,84.0,0.0, 000001,8.35,0,0,0,Enabled
,9.40,5920,0.90,1.79,24.44,9.66,5440,84.0,0.0, 010001,9.14,0,0,0,Enabled
,10.18,4440,1.05,2.11,21.04,10.44,4400,84.0,0.0, 010001,9.92,0,0,0,Disabled
1,10.97,4320,0.45,0.00,9.09,11.51,4280,84.0,0.0, 010001,10.70,0,0,0,Disabled
,12.05,4200,0.40,0.00,7.98,12.33,4160,84.0,0.0, 010001,11.78,0,0,0,Disabled
Any help is appreciated!
Old Jul 6, 2005 | 07:01 PM
Audone's Avatar
Junior Member
I currently only have the shareware version, but wil get my buddy with the full to help tommorow
Old Jul 7, 2005 | 08:20 AM
Alpha7's Avatar
Junior Member
I got that code due to a dead MAF, also got a CEL out of it.
 Michael S. Palmer
Old Jul 11, 2005 | 02:08 PM
LaR H 88's Avatar
Elder Member
2nd on the dead maf...no CEL here
Old Jul 12, 2005 | 05:32 AM
Audone's Avatar
Junior Member
Replaced ther MAF, and it runs fine now! Thx
