Performance and Tuning Discussion forum for various performance tuning techniques and questions
How do non-DBW ECUs control boost?
Old Sep 19, 2003 | 05:32 PM
MK3Audi's Avatar
New Member
Default How do non-DBW ECUs control boost?
Since we don't have a MAP sensor but only a MAF and its so easy to overload a MAF aparently.
How is it done?
How does it prevent turbo overspool?
(with a MAP sensor is easy, but a MAF alone???)
Old Sep 19, 2003 | 06:04 PM
Shep 1.8T's Avatar
Member
Default As I understand it the wastegate opens and vents exhuast out, instead of driving the turbo.
On older turbo's a spring tension to control the wastegate. New cars use a soleniod to control the wastege, allowing tuning to be done through the computer to control when the soleniod operates.
Old Sep 19, 2003 | 07:12 PM
Mat Indukts Lambos's Avatar
Banned
Default Not an exact definition, trying to keep it simple......
NDBW's use maps, deviated by MAF, O2, ECT, knock, load, & throttle angle sensors.
DBW's use the same things, but also add in the MAP sensor in the IC. This allows for more smooth power.
Both have a solenoid valve that control the wastegate, the N75 valve, electronically controlled by the ECU.
Both utilize parameters for each sensor, which set DTC's when those parameters are exceeded. Depending on which one is out, the ECU then has additional maps commonly referred to as "limp mode".
Limp mode can utilize several things to reduce damage to the engine. advance/retard ignition, zero out boost, ignore sensors as determined faulty by the ECU maps, etc, while still allowing you to "limp" home....
Confused yet? ;-D
Old Sep 19, 2003 | 11:47 PM
MK3Audi's Avatar
New Member
Default Re: Not an exact definition, trying to keep it simple......
well, I understand all that you explain, except I still fail to see how the non-DBW A4 1.8t can acurately control boost to 1.0bar for example.
How does it know if its at 1.0 bar as opposed to 1.2bar.
I didn't think the MAF was that accurate.
Old Sep 20, 2003 | 03:32 AM
Banned
Default Between the MAF, O2 sensor, throttle, rpms, engine load and using the maps of where the ecu
thinks everything is supposed to be at, it knows when to start bleeding exhaust through the wastegate to maintain 1.0 bar. That's (in a nutshell) what gets changed when programmers create a higher powered chip, by altering the maps to allow higher boost.
Old Sep 20, 2003 | 06:31 AM
MK3Audi's Avatar
New Member
Thanks. not what I was hoping for but...
Old Sep 23, 2003 | 05:34 AM
Ray Khan's Avatar
Default how is does the K03 work with a 2.0liter?
is isnt it too small for that displacement? Sounds like a great setup for a bigger turbo.
Old Sep 23, 2003 | 08:42 AM
MK3Audi's Avatar
New Member
Default Re: how is does the K03 work with a 2.0liter?
well, until I can get an intercooler installed I'm running with 0 boost.
But, I'm sure youre right. Since the K03 is too small for a 1.8 I can't even imagine whats going to happen once I get the thing connected.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 23, 2003 | 10:15 AM
Ray Khan's Avatar
Default what are your plans for the car?
there is a used t28 kit for sale...that would be sweet.
Old Sep 23, 2003 | 03:48 PM
Banned
Default There's a new turbo kit out (E-05), that's designed for the 2.0L....
It's higher cfm than a K-04, and not quite as aggressive as the T28 or APR's S3. It costs around $12-1300 for the kit, and can be run on any K-04 software but with TT 225 injectors. Also, here's a clue, it's sold by the same company that sells the 2.0L parts, and it bolts right up to the stock cat & manifold.....
I have yet to play with this new turbo setup, therefore I have no testimonials, but I think I may be leaning towards trying it....
Sloooo4esT
Audi Original "S" Cars
Dec 4, 2007 11:15 PM
Beater
Jul 10, 2006 06:27 AM
BigEd
Sep 11, 2005 07:27 PM
NotANumber
22
Jul 26, 2005 11:08 AM
iguanajm
Aug 19, 2003 10:46 AM
