I want to go big turbo: Need some direction/advice.
I have a 99.5 Audi A4 1.8T quattro with tiptronic.
I need some advice about tuning.
I want to do a T-28 turbo, with a custom manifold made by someone local that I know is capable of very professional work.
1) I want to see if there is some sort of chip already out to base my kit off of. I can't seem to get straight help from anyone regarding tuning, and I'm hitting dead ends already even though I've only called a few places. I want to see if GIAC has some file out already for a T-28, since PES has a kit. However when I called PES they told me it wouldn't work without "specific" parts. All an ECU is, is a/f, boost control, and timing. He's saying I need specific stuff. I told him it wouldn't mean anything if I got a different manifold, a similar turbo since a T-28 is a T-28 pending I got the same trim, etc. All that would matter were injectors, and MAF sensor. But he wouldn't tell me what they used which is understandable. So should I go with that software and try to find out what MAF sensor they use and injectors?
2) I'm sure half of you are going to say I will blow my transmission. Thats my next question: can I hook up an Apex`I AVC-R up to the ECU of my car to limit boost in 1st gear and the bottom of 2nd? AVCR is basically an expensive boost controller, and I know people run EBCs and MBCs...how is that done?
3) Anyone here do a T-28 kit from the ground up themselves? What did you do for tuning? Can you help lead me in a direction?
My AIM is darkkstar1337, it might be easiest to talk there.
Thanks much.
Thanks much.
Revo has posted saying that the big turbo software is not
part of the software line, more a small turbo chip that has been changed most likely with Lemmiwinks by one of their dealers.
thewatcher101
05-16-2007 11:57 AM
S4Patrick
04-28-2006 05:00 PM
Phishie [K04]
06-16-2002 11:04 PM
