I want POWER overstear,is there a EDL or torsen controler for S4.
I am looking for a 25/75 torque split.A higher initial torque and accel side limited-slip at the rear wheels.
Tire pressures...
...will help give you some degree of oversteer.
A little lower (28-30psi) in the front, and slightly higher in the rear (38-40psi or max. pressure printed on side wall of tire).
This should help the rear end "turn loose" sooner.
what you need is higher spring rates in the rear
im currently running Eibach pro-kit's in the front & neuspeed Race's in the rear along with a Neuspeed 19mm rear sway bar & it adds just a touch of oversteer
with a bit more stering input the car lets the rear loose smooth & predictably then comes back as soon as power is applied
Stasis makes custom springs & they could probably get you set up with something that will make you happy. but be warned, stasis stuff is top of the line & it ain't cheap
if your looking for "power" oversteer, you really need a RWD car, but Stasis also makes a modified Torsen diff that will send more power to the rear & that will prob help<ul><li><a href="http://www.stasisengineering.com/">Stasis</a></li></ul>
No Bozos!
Looky here
<ul><li><a href="http://www.se-r.net/car_info/suspension_tuning.html#Understanding%20Vehicle%20D ynamics">Suspension basics</a></li></ul>
VorsprungTT
03-31-2008 12:02 PM
s4wood
32
10-17-2006 06:43 AM
x-ricer
11
12-14-2002 03:41 PM
