Performance and Tuning Discussion forum for various performance tuning techniques and questions
Ignition Timing
Old Mar 22, 2004 | 08:38 PM
Shams's Avatar
New Member
Default Ignition Timing
I was logging Engine block number 003 to look at my ignition timing data, after doing a timing belt change and noticed all my readings are negative. At idle I get -9 and they increase to
-35 as rpm's increase. What does a negative number mean? Advanced or Retard. This data is for actual ignition timing not Ignition timing retard found on block 20, which by the way never changed from 0 for all cylinders. Is this a normal reading or is my timing off? I have a GIAC chip in if that makes a difference.
1997 A4 1.8tq
Old Mar 22, 2004 | 09:02 PM
Audi2ptzero's Avatar
Elder Member
Default Non dbw reads adv as a negitive #.
Your readings are normal, just need to log them while at wot and see what your getting.
TEF1701
25
Dec 1, 2012 02:31 PM
lapacoz3145
VAG-COM Discussion
Apr 24, 2009 10:29 PM
Mr Paul [T-28]
Dec 11, 2005 05:31 PM
a4avant99
Oct 3, 2005 09:06 AM
Shams
VAG-COM Discussion
Mar 15, 2004 02:32 PM
