I'm installing an oil cooler, is 10NA a good size for the lines
i'm worried they might be to big and might over tax the oil pump or something. my core is about 8 inches by 10, bigger then any of the other coolers i've seen. I choose this size because people with smaller cooler are still seeing temps around 250 on the track and i would like to keep temps around 200.
anyone have any experences with oil cooler design for a 1.8t w/ big turbo? thanks
It's 10-AN ;-)
I don't think there would be any problems. Your working pressure may change a little bit. It can't get too high, the pump should have a pressure relief valve in it. If anything, your pressures could be lower, if I'm thinking about things correctly.
Rest In Peace
Dude I told you I saw 200 max at the track until we put the goddamned cooler
right behind the IC outlet to TB pipe, perfectly placed to divert airflow AROUND the core. =/
Shep 1.8T
09-23-2005 09:21 AM
virtuapete
05-26-2005 07:54 AM
Gldnrkt(GT3076R)
03-20-2005 08:42 PM
