Boost creep is part of the tuning, so as long as the tuner anticipates it, the problem is controlled
But as Lucas pointed out, external will always have better control or elimination of boost creep. This is because the more expensive valves pop open vertically, not hinged as in an external wastegate. The hinged gates (imagine a trashcan lid opened by a foot lever), will always have uneven opening area as they start to open. This crack is what is anticipated to minimize severe boost spikes. For example, if you want the turbo to start opening around 10 psi, you might want to start applying pressures around 6 (called crack pressure) to an internal wastegate so that by the time the gate is open enough, it's around 10. FOr a good external gate, you can almost just let it open at 10, or a smaller value closer to 10.
