Just installed that Walbro hi flow pump, & a new fuel filter....
Thanks for that helpful write up, John.
I made the spacer like you said, but it came up short. I ended up welding some nubs at the top to space it out enough ;-) (Yes, I welded it in the gas tank) :-O
I have enough to make a few more, so if anyone wants one I'll be able to chop off a requested length.
I'll be replacing the adjustable fpr with a Neuspeed unit, IMO they're better. I took it out for a drive, and fuel pressure went higher at full boost, but not by much. I'll have to play with it some more....
Congrats Matt...I might need that spacer too if u dont mind...Ill prolly try and do the pump myself
and try to save some money. Lemme know how much u want me to give u for that spacer. Thanks
-Amiel-
-Amiel-
It's no problem, as long as you have a way of cutting it.....
I'll give you a chunk. When I cut mine, to .7" as John Bass had described in his writeup, it came up short for me. Might be different on every one, just a little. So, like I said, if you have a way of cutting it, I could give you the piece, talk you through it some, & you'll be good. Or just disassemble it, and bring it all to the shop. I'll help you with it there.
It's gonna be nice having a car so close to mine, to be able to compare things. You'll also have to see the new intake I just made!
Catamount90
05-09-2006 12:48 PM
ButchHusky
13
10-11-2005 06:53 PM
quattro.pilot
9
12-29-2003 09:53 AM
quattro.pilot
12-19-2003 09:05 AM
mroberts
12
08-13-2002 03:15 PM
