Just tryed to install boost gauge, boost isnt reading...
<center><img src="http://images.fotki.com/v2/free/e812/3/30429/100549/BoostGaugeInstall003a-vi.jpg"></center><p>What did i do wrong?? i tapped into this tube, i thought it would work, but nothing reading, Help????<ul><li><a href="http://public.fotki.com/JohnJacobJingleheimer/boost_gauge_install/boost_gauge_install_003a.html">http://public.fotki.com/JohnJacobJingleheimer/boost_gauge_install/boost_gauge_install_003a.html</a</li></ul>
Did you follow the line to the intake manifold to make sure it wasn't placed on a different
side then mine? That hose should lead you to the left side of your intake manifold, slightly right of the FPR line.. What type of connections did you use? have any pictures of the install?
there is a small pipe coming off on the rightside of the intake manifold..
you will see that this little pipe is directly connected to the intake manifold (where the pressure/vacuum occur)
you want to tap into this pipe.
other place would be to tap into the small pipe conecting to the Diverter Valve.
make make sure your connections are air tight and no air leak.
good luck.
good luck.
Re: there is a small pipe coming off on the rightside of the intake manifold..
<center><img src="http://pictureposter.audiworld.com/26754/p3090009a.jpg"></center><p>In this pix is were i hooked it up, the red is the line i hooked to and where it goes, the green is the other line next to it, going just infront of the other, the yellow is the boost gauge line.
Am i in the wrong area?? if so pix of were to go will help alot. thankx
Did you try and see if there are any leaks? Are you 100% sure the boost gauge is in working order?
This is strange.. did you check the connection at the manifold to make sure it didn't fall off?
deeprecon1
10-25-2009 08:19 AM
T-28-Quattro de VT
09-15-2002 01:48 PM
