k26 turbo?
Depends on what you want. I ran a hybrid w/k26 hot side and K27 cold side to ~400whp on an I5
The straight K24 was used on URS4 and could support 300whp. Someone should have a compressor map for you to check. I would recommend the Garrett line tho if you are looking to buy, much wider selection and better technology, and actually cheaper.
Re: Depends on what you want. I ran a hybrid w/k26 hot side and K27 cold side to ~400whp on an I5
well im looking to go the cheapest possible way but with alot of hp gain for now, since i can get a good deal on a k26, and fab up the mainfold my self, would there need to be any other stuff done to it or is it a direct swap with the new manifold, also since i am running a mtm stage 1 chip?
Chip is not enough for that turbo, written for K24. MTM has other chips that should match better
I think you will have some real problems with that chip and such a bigger turbo.
kloop
15
01-17-2002 03:21 PM
StevenH
04-21-2000 10:20 AM
