Performance and Tuning Discussion forum for various performance tuning techniques and questions
Lean problem - here are the numbers (and graph)
Old Mar 20, 2001 | 05:09 PM
  #21
DK's Avatar
DK
Member
Default My mistake
I thought that field was for timing correction
Old Mar 20, 2001 | 05:19 PM
  #22
James R.'s Avatar
Default Actually there is a block for timing correction though it shows like
Cyl 1 - Cyl 2 - Cly 3 - Cyl 4
It displays in degrees retarded from the Mapped values I think. Don't remember the block...I'd have to look it up..
Regards,
James R.
01 Geo Metro 4 Dr.
Old Mar 20, 2001 | 05:51 PM
  #23
DK's Avatar
DK
Member
Display Group 20
Old Mar 20, 2001 | 06:34 PM
  #24
xr4tic's Avatar
Default Here are some graphs I came up with.....
unfortunately my POS laptop can't run 3 data blocks and a screen shot utility at the same time.
Outside temp was 52 degrees F, all runs in 3rd gear.
I used VWTool for the first two, and OBD tool for the other two.
Setup: Stock K03 w/GIAC chip, Scorpion exhaust, and cone intake.
Old Mar 20, 2001 | 06:35 PM
  #25
xr4tic's Avatar
Default graph 1
<center><img src="http://pictureposter.audiworld.com/12130/graph1.jpg"></center><p>
Old Mar 20, 2001 | 06:37 PM
  #26
xr4tic's Avatar
Default graph 2
<center><img src="http://pictureposter.audiworld.com/12130/graph2.jpg"></center><p>
Old Mar 20, 2001 | 06:39 PM
  #27
xr4tic's Avatar
Default graph 3
<center><img src="http://pictureposter.audiworld.com/12130/graph3.jpg"></center><p>
Old Mar 20, 2001 | 06:40 PM
  #28
xr4tic's Avatar
Default graph 4
<center><img src="http://pictureposter.audiworld.com/12130/graph4.jpg"></center><p>
 Michael S. Palmer
Old Mar 20, 2001 | 06:50 PM
  #29
xr4tic's Avatar
Default Hmmmmm.......
That's interesting. At 6500 RPM, with injectors firing every other cycle, max duty would be 18.46ms, so I guess I can see why they cut it off. It seems wierd that the injectors max out at 2500 RPM.
Old Mar 20, 2001 | 06:55 PM
  #30
xr4tic's Avatar
Remember injectors fire every other stroke, so divide you duty cycles by half....
