Performance and Tuning Discussion forum for various performance tuning techniques and questions
It Lives!!!!!!!!!
Old Mar 30, 2004 | 04:34 PM
Lucas_Gchips's Avatar
Default It Lives!!!!!!!!!
Well finnally got the Car initially running again.
Initially i say, as they are some more changes to be made over the next week or so.
like Install a new Performance exhaust manifold.
GT30 Turbo and Autronic SM2 Standalone ECU.
Mods Completed this time;
Custom Engine Build to 2.0L
JE 8.5:1 Pistons with premium Rings
Arrow H Beam Rods with 3/8" rod bolts
VW Forged 2.0L Crank with knife edged leading faces.
Sonic lined Bored 1.8L Block and shaved for conrod clearances.
Eurospec mains Girdle and ARP Rod Bolts.
Custom Intermediate drive Shaft for oil pump.
Head ported, Flow tested, and Ceramic Coated.
Solid Valve Lifters.
Schrick double exuast springs and schrick single inlet springs.
Schrick Single groove valves with larger exhaust valves.
Titanium Spring retainers and locks.
AudiSport mechanical cams.
Eurospec Adjustable Cam sprocket
Ported Inlet Manifold
Modified Oil Pan
Modified Oil Pump pickup
Spec special Clutch
Tial external Wastegate
List of suppliers and or people involved.
Euroclass Automotive
GIAC
Jeremy from Matrix engineering
AWE-Tuning
HPC Coatings
Eurospec sport
Steve Nichols from Aussie Imports LLC
Ray Hall Turbocharging
Eddie Woods from Head Stud Developments
Brendon from Motor Improvements
Garret from ATP
Brian from Racetech
I wish to thank every one and my apologies to anyone i may have missed.
stay tuned for photos and performance results..
Old Mar 30, 2004 | 04:59 PM
Bryans12v's Avatar
Default Way to go!
Good luck w/ the fine tuning.
Cant wait to see those time slips.
Old Mar 31, 2004 | 05:13 AM
HJB's Avatar
HJB
Default What did you use for solid lifters...
shim under or shim over?
Old Mar 31, 2004 | 08:42 AM
MFZERO's Avatar
Wow!!!!!!!!!!
Old Mar 31, 2004 | 02:08 PM
SKS's Avatar
SKS
Junior Member
Default Good for you Lucas! Two questions...What did you do to your intermediate
drive shaft? I have looked at those things and thought (boat anchor). Are you running a harmonic balancer?
Old Mar 31, 2004 | 02:33 PM
Default Re: What did you use for solid lifters...
You use the Hydrolic units, take the center piston out, Schrick supply a new center piston, so its a conversion.
My Valves where tipped for clearance
Old Mar 31, 2004 | 02:49 PM
Default Re: Good for you Lucas! Two questions...What did you do to your intermediate
The gear on the intermediate drive shaft does not clear the rod on cylinder 4 on a 92.8mm crank.
The Gear was actually ground down with a 45 deg Cut to give it clearance.
Also the Shaft is Cast, the whole center section wobbles on a lathe, they are all like that, so we slightly machined the center shaft also.
Old Apr 4, 2004 | 06:09 PM
nscirocco's Avatar
New Member
Default Re: ...What did you do to your intermediate
<center><img src="http://forum.vwsport.com/files/sdscn2032.jpg"></center><p>i just did mine to clean carrillos, there was only 11 thou' clearance before ... here's a pic
 Michael S. Palmer
STASIK_A4
Australia Discussion
Feb 20, 2016 04:33 PM
quattro nole (Jeff)
Rocky Mountain Discussion
May 3, 2007 04:36 PM
Quattro-X-2
Sep 13, 2005 08:38 AM
SteveJ_in_TX
9
Oct 4, 2004 02:05 PM
Lucas_Gchips
12
Apr 26, 2004 06:47 PM
