LLtek Blow Off Valve
Um, what do you do with your recirculation (bypass) valve?
If you shell out your hard earned coin for the blow off valve, what do you do with your recirc valve? There appears to be no replacement for it in this kit, so now you have both working at the same goal but for very different ways. It seems to me that it is a great way to exhange your money for a rich stumble, and perhaps a bit of "boy racer" chuff when you back off the throttle so you can keep up with the Type R boys as far as "whack mods" go.
Also, you are inserting a fairly rigid pipe into an area that is designed to be a flex area to accomodate engine movement. You may well crack something, and anyone can see that 2" of flex at the rubber hose connectors is not equal to the 10" of rubber gooseneck it replaces.
I wouldn't waste my money.
20valvevermont
04-14-2004 09:00 PM
jsyang15
05-03-2003 09:21 PM
UCLAlumS2K
12-15-2000 11:12 PM
