Performance and Tuning Discussion forum for various performance tuning techniques and questions
Loss of Torque??
Old Nov 10, 2000 | 09:21 AM
vis's Avatar
vis
New Member
Default Loss of Torque??
I just chipped my car and am having a great time.
I have noticed, however, that under heavy acceleration (floor it) the power seems to decrease at about 5k rpms (2nd gear floored).
Is this due to the fact that the torque "rolls-off" at about 5-5.5k (i.e. limitations of the engine w/ chip), or that the rev limiter (which is supposed to be at 7.1k is kicking in early)?
Thanks in advance.
'00QC, APR Stage I, Bailey.
Old Nov 10, 2000 | 09:25 AM
Rich L.'s Avatar
Member
Default It's the little turbo.
The K03 just can't flow enough air to keep boost pressure up above 5.5K or so. That's why I went to a larger turbo. Big bucks for big boost.
Rich
Old Nov 10, 2000 | 11:42 AM
WClark's Avatar
Member
Default You mean a gradual reduction in torque, right?
Check the APR published torque curves and you will find that is normal.
If it very sudden, then something else is going on that is not normal.
Old Nov 10, 2000 | 11:54 AM
vis's Avatar
vis
New Member
Default Re: You mean a gradual reduction in torque, right?
yes, the car's still pulling, just not as much as
before.....
I think it's normal.
Old Nov 10, 2000 | 02:17 PM
PanTTher's Avatar
Default Depends on the chip's programming. For example my GIAC maintains boost at high rpm whereas mtm...
lets off sooner. Are you still using your stock bypass valve?
enis77
2.0T FSI Discussion
May 19, 2008 03:43 PM
SlutMonkey
Mar 22, 2006 10:03 AM
wuride1
Apr 27, 2002 08:56 AM
spider418
10
Jan 4, 2001 11:47 AM
me
Jun 4, 1999 02:05 PM
