MASSIVE UNDERSTEER!!!!!
Given the lack of information about your driving, such as type of driving (i.e. track, solo ...etc.), current vehicle setup as well as experience the only thing I can suggest is Hire a Pro!
increase rear toe-out (if you go too far it'll eat tires like you wouldn't believe, DAMHIK)
stiffer rear swaybar
max front camber - wheels tipped in like this /-o0000o-\
min rear camber - wheels tipped out like this \-o0000o-/
Depending on the car and the settings, this combination can be VERY effective, so be careful. I managed (with this plus a coil-over setup and camber bolts) to get my 80 quattro to be a little too tail-happy and had to back it off a notch or two.
Softer or removed front sway bar would probably help, too, but I haven't tried it myself. You can induce oversteer with the "Scandinavian Flick", but you'll want to practice it in an open area before you try it on a narrow track. http://www.drivingfast.net/technique...vian-flick.htm
